The screen is detached
Hi
The display from the top is separating.
5 cm from the top and 3 cm from the left separted.
How can i fix it?
Hi
How can i fix it?
It's a common issue with aftermarket screens and bad adhesives.
To fix this you will need to use a combination of B7000 liquid glue and Tesa 61395 tape and let the glue cure for about 48 hours including clamping the screen down to the frame.
Unfortunately that's how it is with aftermarket replacement screens on the Z3, bad design for holding the screen down with adhesive, main reason why I don't do them anymore.
The best solution is to replace with new one or you can do it by the help of surgical blade place some of super glue gently and put some rubber bands on let it set for couple of minutes.. and you will be sweet
Good answer, didn't think of that even though I've done that before.
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 9
Total : 144
