Hi @treatment1 ,
Did you spill any liquids on the keyboard at all?
If you have you may have to check the motherboard as well for any damage.
If you haven’t then perhaps it may be a keyboard cable connection problem or a faulty keyboard
Try plugging in and using a USB keyboard until the laptop’s keyboard’s cable connection can be checked or the keyboard is replaced. You can cause more problems than what you had when attempting to repair a keyboard.
Here’s a link to the service manual for your IdeaPad.
Scroll to p.43 to view the necessary pre-requisite steps and then the procedure to remove the keyboard. You can check the keyboard cable connection when doing this.
Scroll to p.78-79 to view the part numbers for all the keyboards available for your series IdeaPad. Find the part number for the keyboard appropriate to your particular model variant. The part number is also sometimes printed on the underside of the keyboard so that you can verify that you have the correct number.
Once you have the part number, search online using the part number only in your browser’s search box, to find suppliers of the part.
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
1 commentaire
Yes, thats a coincidence, also if you have a problem then please open up a new topic.
par FinalplayerRyu
