Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La mise à jour de mars 2015 du MacBook Air 11" d'Apple est dotée de processeurs Intel Core i5 et i7 de cinquième génération, offrant ainsi une légère amélioration des performances et de l'autonomie de la batterie.
trackpad wont click down at all
when i say it wont click, i mean it is tap reseponsive, it just wont click down, its been happening for about a year now and i need help. it will not click down as in i cannot drag photos or files without the help of a mouse.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Solution retenue
Your model uses a touchpad which unlike the older trackpad does not have a mechanical clip plate. There is no means of adjustment only replacement. Here’s the IFIXIT guide you’ll need to follow: Remplacement du trackpad du MacBook Air 11" Début 2015 and here’s the needed part: MacBook Air 11" (Mid 2013-Early 2015) Trackpad
Image Replace a trackpad compatible with the Mid 2013 to Early 2015 MacBook Air 11" model A1465 laptop. Part #923-0429.
Produit
$57.99
Indice 1
Actually there is an adjustment screw that you could try before replacing the trackpad, if you have the laptop open, it is at the bottom center, right below the trackpad, you can see it in the video thumbnail. It is a T5 screw. Try that first before replacing the trackpad.
Indice 0
1 commentaire:
If the trackpad does not click, how would I use the screw to adjust or fix that? Thank you.
par
Ajouter une réponse
Logan Emtman sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 1,191
