Aller au contenu principal
The LeapFrog LeapPad Platinum 31565 combines a 7’’ high-resolution, multi-touch screen with a powerful quad-core processor. It is the latest model in LeapFrog’s line of learning tablets.
19 questions Voir tout
Microphone is muffled but speaker works great
The microphone on my son's LeapPad Platinum won't pick up sound or rather it is extremely muffled. We turned the unit off and back on again and it is still muffled. Any suggestions?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi,
Use a strong light and a magnifying glass to see whether the voice inlet hole in front of the microphone may be blocked.
If it is (or even if you can’t tell), try using a vacuum cleaner to clear the hole of any blockage.
DO NOT use a pin or probe to try and clear the hole as you may damage the microphone.
Here’s an image which shows the location of the voice inlet hole (and the microphone position in the tablet).
(click on image to enlarge for better viewing).
If doing this doesn’t resolve the problem you may have to open the tablet so that you can access the case from both sides to visually inspect that the voice inlet hole is unobstructed.
If it is blocked then it will be easier to clear without causing any damage to the microphone.
Here’s a link to the ifixit Remplacement de la carte mère du LeapFrog LeapPad guide. It is useful as it shows how to open the tablet so that access to the voice inlet is possible.
If the voice inlet hole is clear then there may be a problem with the microphone itself.
Indice 1
Ajouter une réponse
dogsrpepl2 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 154
