Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
It's a hardware issue, now this can be caused by a number of things:
- Charging port physically damaged: Visually inspect the port with a flashlight and look for any corroded, bent, missing or bridged pins that are touching each other. This includes the plastic part under the pins being worn too.
- Clogged up charging port: If this is the case, the charging cable may not plug in fully meaning you need to clean the charging port with something like a toothpick carefully.
- Liquid damage / corrosion behind the charging port pins: To confirm this you need to open up the device and check the charging port daughter board for any white marks / corrosion. Sometimes you can fix this with 99% isopropyl alcohol brushing and/or resoldering else you need to replace the charger port.
- Loose battery connector due to bad solder joints causing a bad connection between the battery connector and the logic board. This can be fixed by resoldering the battery connector to the board. I recommend taking the device to reputable repair shop that does soldering to fix this for you.
- Lastly, but least likely is the battery being faulty: This can be the case but it happens rarely.
4 commentaires:
Hi and Good day,
i have checked the charging ports inside and outside which seems okay with not bents or corroded part.
for loose battery connector. I'm not sure if its bad soldered.
i've read in some forums that it doesn't charge because the LCD display is frequently eating the small battery charge when it is powering up. i'm looking where is the ribbon connector of display where in i can disconnect and charge the battery by itself.
i see. one of the thin aluminum thing near the battery is warming up. the largest one.
if it's booting up until to the logo with circle loading in it to 0% battery logo until it shutdown immediately. does this mean it charges and the charges port is ok? or i'm failing to check on something?
