Why is my laptop screen going blank?
My laptop screen went out and now its all just dark screen. The battery is fully charged and I can still power it on and log in. But then the screen just went out. Please help!!!!!!!!!!!!!
Hi @sasres
Just verifying that the screen works when you go to login (splash screen and Windows startup screen etc and then it goes black after login, is this correct?
Connect an external monitor to the laptop and check its display is OK or not
What OS is installed?
If you have Win 10 installed try starting the laptop in safe mode and check what the laptop's display is like.
par jayeff
I had the same problem. Tried restarting in safe mode, but the computer shut off again. I tried resetting windows 10, but the laptop shut down before completing the analysis. I was away for about 10 days and I left the laptop unplugged. Once I plugged it back in, I have been able to use it. I'm suspecting a battery problem may have been the cause. So far it hasn't shut off after two or three hours use.
par Don
Please my problem is, I’m having a faulty battery so after putting my charger inside the laptop when I try to start it the power button on for sometime and goes back off without seeing anything on the screen…
Can anyone help please
par Chris Kweku
