no speaker sound after power connector assembly replacement
I have a Galaxy Tab A SM-P550. charging port stopped working. Purchased replacement assembly. Installed following IFIXIT procedure Remplacement du port de chargement du Galaxy Tab A 9.7. After reassembly charging works but no sound from speakers. Sound in headphone and bluetooth audio works. Re-installed original part; same thing, no speaker sound, headphone and bluetooth work. Speaker sound worked before power connector assembly replacement.
Used S/W tool to disable wired headphone detect. no speaker sound.
soft reset. no speaker sound
returned device settings to factory. no speaker sound.
Is it possbile I damaged both speakers? - How to know?
Does the wired headphone detect pass through one of the flex connectors on the power connector assembly (short would diable speakers).
Any ideas where I could go with this?
I have debugging experience (EE), Can you get schematic for power connector assembly?
Maybe Paulina Nguyen could ehlp with this. She wrote the connector replacement procedure for IFIXIT.
Thanks in advance,
Brian
