Aller au contenu principal
The S55t-A5389 model of the Toshiba Satellite laptops was released in 2013. Repair of the device requires screwdrivers and prying tools. The device can be identified by the Harman/Kardon sticker between the keyboard and the display.
5 questions Voir tout
Do I need to apply thermal paste to heatsink on laptop?
Still really new to computer building and maintenance - long story short: computer is overheating a little bit, I'm going to try cleaning out the fan and seeing if that fixes the issue. The question that I have now is when I put it all back together, do I need to apply thermal paste to the processor on a laptop?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
3 Réponses
Solution retenue
Yes!. First, you need to see on the heatsink if your laptop uses paste or dissipative rubber, to be paste, remove the remains of the old paste that should be hard as a stone for the time of use and apply the new paste on top of the processor and the video card (if any).
Try to use only the necessary amount of paste.
Indice 4
2 commentaires:
How do you tell the difference?
- I mean, I know what thermal paste looks like, so if it doesn't look like thermal paste, assume its the dissipative rubber?
par
yes, it´s like a rubber, it could be colored blue, white, yellow, pink.
This is an Amazon link:
https://www.amazon.com/Wathai-15x15x1-5m...
par
If you are going to tear your laptop down sufficiently to where you can get to the CPU, then regardless of whether it is running hot or not, you should change your thermal paste to a high-quality thermal paste.
If your laptop is running really hot, then you should definitely change the thermal paste, which means that you will need to tear it down sufficiently to where you can get to the CPU.
It is a real chore to tear down a laptop; so don't tear it down unless you have a good reason to do so. It is very easy to break a tiny, essential part, so be very careful when you are tearing it down.
It is strongly advised that you wear an anti-static wrist strap (Anti-Static Wrist Strap) when you are working on your laptop, so that you don't damage a part due to static electricity.
Use either Arctic Silver ArctiClean (Arctic Silver ArctiClean) or high-grade isopropyl alcohol (91%) and q-tips to clean the surfaces of the CPU and the heat sink (after you remove the heat sink from the CPU); then apply Arctic Silver 5 Thermal Paste ([produit lié absent ou désactivé : IF179-010]) to almost cover the face of the CPU. The idea is that when you push the heat sink onto the CPU, it will spread the thermal past, so you want it to end up covering the entire face of the CPU. (If any excess comes out, clean it with a q-tip.)
Image Help protect your electronics from accidental electrostatic discharge (ESD) damage during repairs. Ground yourself while working.
Produit
$7.95
Image Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
Produit
$9.99
Indice 2
I will echo the recommendation to apply new thermal compound after removing the old. I will add however, that it is critical that you do NOT have any air bubbles in it. Air is a very good insulator and you don't want insulation here. You want good heat conduction to the heat sink. A little too much compound is better than not enough. Just don't go overboard with the amount. Spread a thin layer without any bubbles across the entire CPU surface. If it spills over the side, again don't go crazy, but it won't be a problem. This compound is a heat conductor not a conductor of electricity.
Dan
Indice 1
Ajouter une réponse
Tyler sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 9,929
