Aller au contenu principal
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
301 questions Voir tout
98 gmc 4.3l v6 oil pan removal
i have all the bolts that i can see from the bottom of the pan, but the pans still hung up i figured it would drop sorta easy with all the bolts out but there must be some i missed. where do i go from here? take the trans out, the whole motor out?
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
Ajouter un commentaire
1 Réponse
Solution retenue
Tap it gently with a small rubber hammer all around the seam. There may be a gasket that's holding it in place. Use a flathead screwdriver on the end to break the seal loose. You can also use the back of your fist and bump it loose.
Indice 1
1 commentaire:
Careful wit the screwdriver that you do not bend the surface for the gasket, or you will have a leaky pan.
par
Ajouter une réponse
steven boomer sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 1,622
