no power even after both power ics changed
so i have an s6 edge+ no power, replaced both power ic’s. getting around 3.5v in both locations but not turning on and no image. on dc power to vbat holding power will draw current but when let go it doesnt draw current like it would if booting
@refectio any ideas what would cause this
par daniel
I'm not really an expert with Samsung devices. You say you changed the power IC's...did you check the output voltages to see if any were shorted? The problem may be downstream.
par Minho
I can second that response by @refectio. Make sure you don't have any broken traces and the voltages are within spec downstream.
par Justin Robison
cant find any shorts on the board altough there are coils above the main power ic that seem short but not sure if its just low resistance lines
par daniel
By definition, coils are "short" as they are just a looped wire. They shouldn't be shorted to ground though.
par Minho
Afficher 1 commentaire en plus
