How do I interact with this tablet with a broken screen and battery?
Ok this is a unique case given the limitations:
- The screen is dead with no way of repairing
- The battery is also dead
- It supports OTG, however since there is no battery, I can’t simply attach a mouse to interact with it.
It has these specifications:
- Supports OTG
- Has HDMI support
- Has SD card slot
From this, I have two options which I have narrowed down:
- By connecting it to a Macbook Air, where I can interact it (given there is a method that does not require USB debugging and no root.)
- Connect it via OTG, but via a USB hub where I can charge while having a mouse input at the same time. Is there such a thing?
2 commentaires
Hi @rwalmond ,
Have you thought about fully charging the battery first and then using an external monitor connected via the mini HDMI port to view the display whilst you scroll through using an OTG connected mouse and then transferring data via WiFi or to SD card?
I'm thinking that if the battery is faulty as opposed to just being "flat" that trying to connect power to it and using a mouse at the same time mightn't work, but not sure about this.
par jayeff
Yes I have tried to charge it overnight with the original adapter, however it didn't charge and it registered the battery level as 1%.
Also, the screen works fine. It's the touch overlay that is broken.
So, that is why I still think there is a way for an OTG input while having it charge at the same
par [deleted]
