Aller au contenu principal
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
20 questions Voir tout
MacBook Pro 2012/13 Blade Ssd Sandisk SD5SL2 512Gb - Faulty
Couldn’t find any better category to describe it, hope description will suffice. It’s an SSD I got some time back with a Macbook Pro I bought for parts I needed, seller was clear enough to state it might have been faulty, and that’s what it seems to be indeed. Since it’s an Ssd installed for quite a short time on Macs, I just have one machine to test it. However, I also have an adapter 7+17 (8+18) pins to SATA 2,5” if needed. It seems the drive can’t be seen or recognized either way. I have no idea if schematics for such drives can be found somewhere around and if it makes sense at all to try a repair, but since it’s a 512Gb drive it would be worth the try. I’ve done some basic testing with multimeter and I can see two voltages, 1.8v and 3,3v on random caps, the SSD mildly heats up as if it was working without any major shorts..under the microscope everything looks clean and shiny. One of the two coils shows a 1,05v. Has anyone ever succeeded or attempted an SSD hardware repair and can provide some insight ? I enclose a couple of pics for reference.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
Still hunting for schematics of this..any hints anyone ? I know flash drives prices have gone down, but still, feels bad not to be able to fix it.
par
Ajouter un commentaire
1 Réponse
Solution retenue
If I remember correctly this is one of the SSD’s Apple had recalled as the Marvell controller chip (Sandforce) had a defect.
I’m not sure if you can find any schematics for it as Apple does not offer any info on the SSD device side.
Indice 2
1 commentaire:
I wouldn't be surprised if that was the case as these drives very pretty short lived. The controller chip is probably getting the right voltage as the coil close to it shows a 1.05v which would be a typical correct value for a processor.
I'm aware it won't be easy to find schematics for it as the same applies to any Apple device, but I still hope some leaks or reverse engineering work might help..I see a few faulty blade Ssd around for sale, maybe someone has found more useful infos and would be able to shed a light ?
par
Ajouter une réponse
arbaman sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 530
