Hi,
The coolant thermostat may not be opening which prevents the flow of coolant through the engine block to cool the engine (and also to flow through the heater radiator in the passenger compartment if the heater is turned on).
This causes the engine to overheat, especially when the vehicle is stopped in traffic with the engine idling, and it also means there is no hot air when you turn on the heater.
The way to check if it is opening:
When the engine is cold, remove the radiator cap and start the engine.
Be safety aware as the engine is running: vehicle in park or neutral, handbrake on
As the engine warms, after a while (check the engine temp gauge) you should notice the coolant in the neck of the radiator start to “flow” or “swirl” indicating that the thermostat has opened and that the coolant is being pumped through the engine.
Be careful as the coolant temperature increases the liquid expands and it might overflow from the neck of the radiator''
Hopefully you’ll notice whether or not the thermostat has opened before this occurs
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
1 commentaire
My 2003honda accord was running rough for like two weeks ,today I got on the highway was doing about 65 when it died,it was hot ,I put water in let sit for about 4hours went to start and it ran like it was hot and barely moved,can any one help,I've changed the thermostat,still losing power
par Shane Farris
