What makes you think it’s short…even a phone that is powered off still draws some current for the “always on” part of the circuit and potentially to charge the battery.
The proper way to test for shorts is to measure with a multimeter with the battery disconnected. Check the BATT_VCC, VCC_MAIN and PP5V0_USB lines to see if they are shorted. You can use Ohms mode or check with the DMM in Diode mode. If those lines are good, then start checking the PMIC outputs. Only when you’re satisfied the phone has no major shorts do you put power on it, otherwise you can damage the board further.
Report back with your findings and we can give you more guidance.
A voté
Annuler
Indice
4
Are you sure it's vbat and not vcc main
par daniel
I have checked it with the power supply on the battery connector,so it is the battery connector line.
par mangustarooficial
Because you have dc connected to the battery connector doesn't mean it's short on the connector line. Set your current to 2 amps then feel for heat obviously u will feel heat around the Tristar area but that is normal
par daniel
