What is the Maximum upgrade for DELL M731R 5735
what is the Maximum Ram, and Hard drive Upgrades for the DELL M731R 5735?
Dell Inspiron M731R 5735 Info
CPU:AMD Dual/Quad Core A8 or A10 Series
Memory Type:PC3-10600 1333MHz DDR3 SDRAM
Standard Memory:up to 8GB
Max Memory:8GB
Memory Expansion Slots:2 SO-DIMM Slots
PC Card Slots:None
USB Ports:Two USB v3.0 Compliant Ports and Two USB 2.0 Compliant Ports
Firewire Ports:None
Card Reader:4-in-1 Media Card Reader (SD/SDHC/MS/MS-Pro)
Original Optical Drives:DVD SuperMulti
Original Hard Drive(s):1TB 5400RPM SATA III 6Gb/s Hard Drive
There is no 1TB limit on any PC built today that uses 3.5" SATA II HDs.
If your system sees 2TB from a 4TB HDD, meaning you have initialized it as MBR , you may convert MBR disk to GPT that way.
I've been running 16gb RAM in mine for the past few years.
Does it really use all 16 gb?
Does it really see all 16 GB?
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 12
Total : 1,366
