Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The second generation (KK) Jeep Liberty, a compact 4-door SUV that restored the classic sharp lines of the original Jeep styling.
Where is the actuator located
I need to replace my blend door actuator so my heat will work. Ive asked mechanics and the all tell me that the dash has to be removed but youtube tells me its on the driver side and can be replaced with out removing dash..please tell me this is true
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
heater blowing cold air
Indice 0
Réponse la plus utile
The actuator that controls heat/cooling is located in the area just above the driver's right foot. To access, pull down the panel below the steering wheel, then slide it to the left. It will come off. Then you can see the actuator. There are two. The lower actuator controls the heat/cooling. It has two t20 screws. Very easy to access, remove, replace. The upper actuator controls the direction of airflow (feet, face, defrost). It's upper screw is more difficult to access.
Indice 4
1 commentaire:
Pls the circulation and A/c light is not coming up in my liberty Jeep 2008 what could be the problem
par
Ajouter une réponse
Joseph Schwager sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 23
30 derniers jours : 100
Total : 7,741
