Aller au contenu principal
Tutoriels de réparation et d'entretien pour les cartes mères et les processeurs.
20 questions Voir tout
No Secure Boot and CSM options in asus uefi bios
Hi everyone! Motherboard: asus P8P67 PRO (REV 3.1). In the asus uefi bios I don’t have the secure boot, csm and fast boot options. It must be in “boot” menu, but I have nothing there. I have the last version of bios (Version 3602 2012/11/22). Please, tell me, how can I “unhide” this options? Need it so much. Add 2 images with my uefi bios and another one found in the internet. Thanks a lot!!!.
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
6 commentaires
If the Bios have ONLY UEFI (no Legacy option), you can boot from USB if is formatted FAT32 and not NTFS (or to make UEFI bootable DVD/CD). Many of new PC's/laptop's have only the newer UEFI BIOS (the Legacy Bios is an older option).
1. Download Rufus (freeware, please use the at least the current latest version 3.8)
2. Make a bootable USB flash drive, formatted in FAT32 (!)
3. Put in the PC's, Laptop's USB port.
4. Power on the PC/Laptop and push the ESC (can be F8, F10, etc.. depending on the PC) until you get into the boot selection section.
5. Boot from the USB.
6. Enjoy installing Windows!
par
USB is FAT32 made with Rufus and USB yet doesn't appear in the boot menu, though it's recognized in the USB devices menu... How can I solve this?
par
U can try un Gpt&faf32
Ur microprocesador Is coffelake maybe
par
I have the same problem, The flsh drive thing work but dosent solve my issue. My motherboard is UEFI but I have the old bios which is called lagecy bios and Id like the have the ASUS UEFI BIOS Utility - EZ Mode interface. Dose anyone know if It can be done or am I wasting my time?
par
Hi @Daniel Melancon,
The motherboard is nothing to do with UEFI it is the BIOS/UEFI that determines this so could you perhaps reword that question? Perhaps you are talking about the hard drive?
par
Afficher 1 commentaire en plus
Ajouter un commentaire
3 Réponses
Solution retenue
Hi @mememe93 ,
Look under the Advanced tab in BIOS to enable Legacy USB support.
Here’s an image taken from the motherboard user manual (Sect 3.18) which shows the options.
(click on image to enlarge for better viewing)
Indice 2
6 commentaires:
already done. still no changes.
par
Hi @mememe93 ,
Have you tried "load optimized defaults" when exiting BIOS to see if this restores the BIOS functions to default factory values and resets the BIOS so that it will work with Legacy USB support enabled?
Make sure that you know (and list) which BIOS settings you've already altered to suit you're requirements, so that you can restore them back after doing this
par
I tried go back to default factory values. Also I tried resetting bios. No result :|
par
Hi,
Did you try going to the Windows UEFI settings to see if Secure boot is there?
In Win 10 go to Settings > Update & security > Recovery >Click Restart Now > under Advanced startup > Click Troubleshoot > Click Advanced options.
Select UEFI Firmware Settings and check if secure boot or CSM is there.
par
wait please.. I have win7x64 ultimate. Does it have such settings? If it has, tell me please, where I can find it in win7. Thanks a lot!
p.s. as google says, it doesn't :\
par
The thing of using Rufus and Fat32 works… It loads Windows 7 Installation but it freezes on the Windows Logo when loading… I dont know what to do because I need to install windows 7 to install some programs that arent compatible with Win10, then do the upgrade to Win10 and all done… but Nope it freezes in the logo, Idk why the !&&* new MoBos are disabling this option!!!! We are supposed to be free to install the %#*@ OS that we want!
Indice 1
2 commentaires:
I've installed a number of older programs by using the Compatiblity Mode.
Now note: apply on both the installer before installing and on the executable after installation.
Select file, Properties, Compatibility, Compatibilty mode, Check "Run this program in compatibility mode for:
" Select Windows 7 or even Vista and finally "Apply" on bottom right of window.
Install and then apply the above to then executable file from Programs Files folder or Programs Files (x86) folder.
Should work. Let us know how it goes.
If program is quite old try Windows XP mode if the others don't work.
OR run something like VirtualBox.
par
I have the same problem as you were with win7 i do search and found out that my MOBO doesn't support CSM it "grayed out default at Disable" (Intel 500 series chipset) and win7 realy need? to boot in legacy mode(CSM:enable)still can't boot with UEFI, Freez at logo win7 and reboot
MOBO: Asus prime h510m-k
CPU: Intel i3 10100
par
Indice 0
8 commentaires:
Didn't work for me. I used linux default disk image writer and the bootable usb worls fine on my friends laptop but not in my asus q406da zenbook. Also there is no CSM support option and i am using bios version 303. please help me I have stuck in this process since last 2 weeks.
par
USB is FAT32 made with Rufus and USB yet doesn't appear in the boot menu (nor CSM option), though it's recognized in the USB devices menu... How can I solve this?
par
Please read before answering. The problem with this MoBo is that USB isnt available in boot menu. I have the same problem. There is no point discussing Rufus or other solutions if the MoBo wont display USB as bootable device.
par
GUys I have the Same Problem , If you dont see the boot from USB option , Formatting a flash drive in Fat32 Is still a possibility. EVEN IF YOU DON'T SEE THE OPTION. Once you have formated the flash drive in fat32 make sure your pc/laptop is turned off, plus in flash drive press power. Now HERE YOU DONT WANT TO ENTER BIOS BUtT RATHER PRESS THE KEY THAT WILL PROMPT BOOT PRIORITY. ONCE the prompt window will apear you will find your FLah drive in the list click it and there you have it youve just booted from USB FLASH DRIVE although the option is not showing in BIOS
QUESTION FOR YOU GUYS.
I have an ASUS VivoBook S15 S532FA , ANd I have no boot option in BIOS secure boot is there but missing Lounch CSM, Fast Boot . Does anyone know how or if its possible to instal Lounch CSM and fast boot.
par
If anyone can help PLS email me at dmwlancon@gmail.com, i've been looking and runing in circles for a while and i've had it officially.
par
Voir 3 commentaires en plus
Ajouter une réponse
Artem sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 41
30 derniers jours : 163
Total : 126,516
