My right click is stopped working.
I was using it casually when I pressed the button and it didn’t work and it didn’t click.
On 99% it’s microswitch. U can replace it .
Find this on your region
https://www.amazon.co.uk/Mouse-Switch-Mi...
U have help here on this website
Remplacement du micro-interrupteur du Logitech Anywhere Mouse MX
Had you tried pressing on other buttons?
Had you test on another PC?
If you press and use a little force, does it works?
If it is under warranty, suggest you to send in for service.
Else….
you need to open up and try replacing the micro switch first.
I just bought 3 switches off of Ebay and replaced the right click myself. It just took some solder and a solder pen.
Dernières 24 heures : 4
7 derniers jours : 24
30 derniers jours : 57
Total : 6,547
2 commentaires
Hello, I have the same issue with the MX Anywhere 2 version, not the 2s. Would you happen to know what micro switches are used in the 2 version? I want to replace them but there is no info online about the type of switches used in this mouse.
Kindest Regards,
Rodrigo Solis
par Rodrigo Solis
So I have the same mouse the MX Anywhere 2, and I opened it up and looked at the numbers on the switches and just ordered them on Ebay. To save you save you some time here is the Switch name and a ebay link.
Omron D2FC-F-7N(10M)
https://www.ebay.com/itm/5PCS-OMRON-Mous...
par Maxthegamer4548
