Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Deuxième génération de la Ford Focus.
How do I adjust angle of front headlamps
Front headlights shining too high, on dark roads oncoming vehicles flickers at me too turn brights off, but it is.
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
Ajouter un commentaire
1 Réponse
Solution retenue
There should be a 'white' hex (Allen)shaped screw at the top of the headlight housing that you can tighten and loosen thus moving the headlight up and down. The best way to do it is park the car so it's pointing at a wall (front towards a wall or garage), turn the lights on and adjust the headlight's beam so they are both level.The Focus has no side-to-side adjustment...only an up-down adjustment. It's done easily using the Allen wrench on each side. Watch the beam change as you turn the wrench....counter-clock-wise makes the beams go up. Good Luck
Indice 8
Ajouter une réponse
ebrahiem sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 12
30 derniers jours : 45
Total : 34,206
