Aller au contenu principal
The fourth generation Nissan Altima (chassis model L32A) was announced at the 2006 New York Auto Show on April 12, 2006. It was the first vehicle to use the smaller Nissan D platform, with a new front and upgraded rear suspension.
Questions au sujet de 26 Voir tout
I keep getting oil in my spark plugs
I keep getting oil in my spark plugs and I’ve already replaced the valve cover and gasket. How can I fix this?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi @noremac168 ,
Is there blue smoke coming from the exhaust?
This link gives some of the reasons for oil in the spark plug well. (scroll down to the Common reasons for this to happen: paragraph)
Indice 2
6 commentaires:
No it’s white but it smells like burning oil
par
Hi @noremac168 ,
White is also not good. It usually indicates coolant getting into the cylinders/exhaust manifold.
Are you also losing coolant?
Does the oil on the dipstick have a milky look or even bubbles?
par
I’m not losing coolant just oil
par
Hi @noremac168 ,
Are all the plugs covered in oil or only one or a couple?
If not all then it may pay to get a compression test done on the cylinders to check if the leak may be through the rings or the valve guides
par
After I replaced the valve cover it’s been just one
par
Afficher 1 commentaire en plus
Ajouter une réponse
Cameron Cranford sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 22
Total : 2,675
