Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le OnePlus 6T est un smartphone Android fabriqué par OnePlus. Il a été annoncé le 29 octobre 2018 et commercialisé le 6 novembre 2018.
I need to clean the speaker holes
Hi every one, i have one plus 6T, i have spoiled a hot liquid candle wax on it, and i was able to remove the damage from the screen (thanks to the screen protector) now am left with only 3 holes for the speaker to listen from (the rest is blocked with the wax), i have tried to apply some heat from the hair dryer with no luck, what do you think is the best way to solve this issue ?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
Hi Raving,
thank you for your answer, i had tried to do this but it didn’t fix it, even i applied heat using a hair dryer then i used the needle, but the surface area is so small that the wax will be hard again while am trying to apply the push through the needle
par
Ajouter un commentaire
4 Réponses
Solution retenue
Try putting the phone is a ziplock and use a hair dryer, the wax should flow out. Alternatively follow the teardown guide ( skip removing the motherboard) and clear out the wax form the inside. Vue éclatée du OnePlus 6T
Indice 1
Try using a needle or a slim pin to clean the speaker holes. If you are careful, you can just take out the wax without damaging anything.
Indice 0
I usually wrap a glue-dot around a cocktail stick and use it to clean the dust out. I find that glue-dots are just the right consistancy to pick up dust, but still firm enogh not to get clogged in your phone.
Indice 0
Vacuum cleaner and a stiff toothbrush. Be careful not to push the wax further inside and damage the speaker.
Indice 0
Ajouter une réponse
Abdullah Al Rawi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 18
Total : 8,034
