Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Sega Game Gear portable gaming device was released in 1991 in competition with the Nintendo Game Boy.
Capacitor problem, choosing capacitor
Good Day!!!
The board is vr1 version of sega game gear. I can't find a 33uf, 0.47uf, 4.7uf, 22uf, 68uf capacitor can I use higher value? Thanks in advance!!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
This is hit or miss, 1206 smd . <1uf use 1uf smd, <10uf use the 10uf, <100uf use 1210 SMD 100 uf
par
Ajouter un commentaire
2 Réponses
Solution retenue
Hi @faustrepair ,
You cannot use higher values than what the circuit design requires. It will change the characteristics of how the circuit operates (if it still will operate that is) if you do.
The type and values of the capacitors were selected for a reason when the circuit was designed
Did you check on places such as this?
Also you’ll have to know a bit more that just the capacitance value. Such as working voltage, what type of capacitor, physical size etc.
Indice 2
This is hit or miss, 1206 smd . <1uf use 1uf smd, <10uf use the 10uf, <100uf use 1210 SMD 100 uf. Few to many years later on this👍🏼
Indice 0
Ajouter une réponse
Faust Tan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 33
Total : 371
