Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le smartphone Android LG K20 Plus a été commercialisé par LG Electronics en mars 2017 au sein de la série K. Le LG K20 Plus inclut les numéros de modèle LG K20 V, LG VS501 et LG TP260.
Why is my phone keeping ringing a weird drum beat sound?
My phone has been acting up lately with this unknown weird sound lately. It sounds like a jazz type of beat and it just won't stop, no matter what I do with it. I restarted my phone, I had to delete other apps that was affected by the sound, and tried everything to make this stop, but it didn't.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
just turn off notifications… this will stop the noise…then you can turn on each app notification that you want …wait to see if its the issue…and continue one at a time…no need to delete them
par
Ajouter un commentaire
2 Réponses
Solution retenue
Hi @markerz2020 ,
Try starting the phone in safe mode to check if it works OK or not.
If it works OK then a downloaded app is the cause of the problem. The trick is to find out which one is the culprit.
You need to uninstall each downloaded app, one by one, and test the phone between each uninstall. When it works OK the last downloaded app that you uninstalled was the cause of the problem
Indice 3
Try resetting you phone.
Indice 0
Ajouter une réponse
Marcos sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 30
Total : 1,855
