iPhone se logicboard replacement
This board is from an se I have and I wanted to replace the broken parts that you see on the picture, I have another se board that’s exactly the same. Can I desoder the parts from that board and soder them back on to my se board. I’m still new at soldering but I’m planning on using mini soldering tweezers. Any advice would be much appreciated.
1 commentaire
Thank you for the reply I took your advice and didn’t touch the board. I’ll probably just use it for practicing instead of trying to fix it. The board doesn’t boot up at all so once I read your advice I figured it was too much to invest in then just buying a new one. Thanks again
par Scott Sanchez
