Aller au contenu principal
Pour réparer ensemble - Je crée un compte
L'Asus VC239H est un écran IPS d'entrée de gamme. Il prend en charge une résolution de 1920x1080 (Full HD). Disponible pour la première fois sur Amazon en 2015. Numéro de modèle : VC239H.
How can I open this monitor?
this is not the specific monitor im talking about, i could not find the one i have on the list. i have a MSI Optix G24C 24in. I spilled water inside it a few days ago and i need to open it to try and wipe down the water inside. does anyone know how i can open this to get to the screen portion safely?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Most modern monitors are snapped shut and don’t use screws outside of the stand. The issue is knowing which way to work. Many of the modern ones come apart starting with the bezel, but some like the Dells are assembled from the front. I would go from the back first to be safe since that’s the more typical way of doing it.
Once you know which way to work, start from the bottom and start removing the snaps. If you have to use harsh tools, work from the bottom to avoid deep visible gouges. Once you have one side unsnapped, do the same for the other 3.
After you get at least 3 sides loose, then you can typically work the final side off by hand on the final side with some caution. If it’s stubborn or edge to edge, it’s best to work all 4 sides off before removing the front or back bezel. I would expect a little cosmetic damage will be done to the monitor since you really can’t avoid it.
This can be difficult to do, especially if it hasn’t been opened by a previous owner. As long as you keep this in mind, you’re not going to break anything as long as you're careful.
Indice 2
Ajouter une réponse
Conz sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 54
Total : 3,796
