What screwdriver do I need
Can someone link me a screwdriver from the ifixit store that can be used to open up a joycon
@andrewifix you need a Y00 bit for the backplate iFixit Precision 4 mm Screwdriver Bit Even better if you get the kit so you have all drivers for most common repairs Mako Driver Kit - 64 Precision Bits
Produit
$39.99
Produit
$2.99
For the inside of the Joy-Con, you will also need a Phillips #00: Phillips #00 Screwdriver
@oldturkey03 gave you some good options, and you hopefully fixed your controller by now, but if you only need a fixed blade screwdriver to open your Joy-Con or Switch, iFixit sells a Tri-point* Nintendo Switch Joy-Con Y00 Precision Screwdriver
*AKA a Tri-wing screwdriver. However, it is slightly different from an actual "Tri-wing Screwdriver." If you are opening a Switch Joy-Con, the screwdriver tip should look like a Mercedes logo.
Dernières 24 heures : 21
7 derniers jours : 216
30 derniers jours : 863
Total : 25,726
