Charging Issue since 4 months
Charging with low power only, heat up. Not charging while shut down.
You likely need a new battery set the main battery is easy to replace following this guide Remplacement de la batterie de l'iBook G4 800 MHz-1.2 GHz You also need to replace the PRAM battery which is located under the top shield just behind the ports. Follow this guide to gain access iBook G4 12" 800 MHz-1.2 GHz Top Shield Replacement. The battery guide has the info for the button battery.
Tutoriel
Difficulté :
Très facile
Tutoriel
Difficulté :
Difficile
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 32
