Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Dyson V6 Absolute est un aspirateur sans fil et sans sac sorti en septembre 2014, doté d'une filtration HEPA qui capture les allergènes. Utilisable sur tous les types de sols, il pèse 2,3 kg. Il est identifiable par le numéro de modèle SV09.
Dyson v6 fluffy brush motor replacement
Hi! My dyson motorhead just broke. I disassembled the brush and found the motor was broken. Tried to fix it but i saw sparks and smoke coming from the inside so I have to replace it. I have disassembled the motor too and kept all the original cylinders, screws and plastic cover. So i only need to find a compatible electric motor and re-assembly everything. My question is, how do i know which motor is compatible? It shouldn’t be difficult to find one in aliexpress but i don’t know what to look for. Somebody could help me please? Thanks!
Update (07/08/2019)
I’ve uploaded 2 pictures. 1st picture is my broken motor with the plastic part that I haven’t deattached yet. The other picture corresponds to another dyson v6 fluffy brush motor fullydisassembled
Upper line numbers: 1030986
Lower line numbers: 9S0231 C3
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
9 commentaires
Hi @mg_alie,
Your pictures are not there.
Here's how to do this in case you're not sure. Ajout d'images à une question existante
par
Hi @mg_alie,
Did you find some way to replace the broken motor (only) ?
Do you have any link for the motor part or @jayeff for the mini motorized tool (it’s out of stock on your earlier link) ?
par
Hi @jsncrdnl ,
Try putting the part number/model number into the search box on this webpage and check if there are any results
par
How did you seperate the plastic from the motor? Any hint?
par
I had to destroy the old motor but it doesn't not bring much. Inside on the axes is an gear with 24? that is stuck on the axes. That you can't take it off (i couldn't) neither to replace it. Inside the plastic is also 2 torx screws you have to take out under the metal washer where the same gear is...i stopped there. For me is no way to fix it ..any suggestions?
par
Voir 4 commentaires en plus
Ajouter un commentaire
3 Réponses
Solution retenue
Hi @mg_alie,
Is there any information written on the motor, e.g. a model number perhaps?
Here's the part number (966086-01) for the mini motorized head for a Dyson Fluffy V6 (SV6) taken from this webpage. Is this what you are referring too?
If you can't find a motor if you search online using the part number only in the search term of your browser, you'll get results for suppliers of the whole motorhead.
Indice 1
2 commentaires:
Hey! I just edited my question with the information you asked. Hope that helps
par
Hi @mg_alie,
Not sure if this is correct but I think that the part number for the motor is 966792-01
Searching online found this link
If this is the correct part that you want it would be more economical to buy the whole mini motorized tool (scroll down the page in the link provided in the answer above to find the part).
if it is not it apologies.
par
it is possible to detatch the motor without destroying it all.
use a screwdriver and hammer to hit the center pin of the cog while holding the plastic (not the motor)
https://photos.app.goo.gl/M8Kv1bomjWxbGJ...
Indice 1
1 commentaire:
Very old thread I know - but in case you see! Any tips here? I've tried hammering it out but loosened it and that is about it (mainly as I took the screws out!) - looks exactly as per yours with the cog but it isn't budging (I don't have a vice so probably not as strong as it could be!) - if you see this appreciate a reply. Cheers
par
In ebay with that number 1030986 you will find coming from ?china? the little motor for about 12€ . Just replace it and you are good to go. Also Google is offering you other alternatives under that number. Good luck!
Indice 0
1 commentaire:
@Rob Kenny did it come off hard? Did you have to apply a lot of force? Mine is pretty stubborn and not moving at all. Any extra advices? Appreciate it!
par
Ajouter une réponse
mg_alie sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 52
Total : 4,730
