CDMA vs GSM replacement back cover
Whats the difference between a CDMA iPhone and a GSM iPhone back cover? Why is a GSM replacement cover not compatible with the CDMA? Do you thinks its possible to make it compatible by removing some of the mounting clips or something else?
1 commentaire
To my knowledge they should both be compatible with each other? The only differences in the models are small hardware changes (logic board) and a different roaming frequency. Have you tried a GSM back cover on a CDMA iPhone or vice versa?
par martin
