Change stand for a vesa mount
It can be change the regular stand for a vesa mount without cutting the stand?
Like dismounting the stand
There are a few ways to do this!
Hinge assembly
Is there a guide to do this?
The other is opening your system to gain access to the hinge assembly internally and replace it and the other parts with the needed VESA mount versions. This is a lot of work as you need to completely disassemble the system
Cheers
@hugolz - You need to remove the logic board following this guide Changement carte mère iMac Intel 21,5" écran Retina 4K (2017) Then review the picture above to remove the stand and then the hinge.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 223
1 commentaire
Cutting the stand off won't get you a VESA mount! All you'll get is a system with no means to mount it to stand it up.
par Dan
