Aller au contenu principal
Samsung WB1100F is a digital camera with the ergonomic feel of a traditional DSLR, but also the ease of use of a point-and-shoot compact. The WB1100F has a 16.2MP CCD sensor with a sensitivity range of ISO80-3200 and a 35x optical zoom lens with a focal range equivalent to 25-875mm (in 35mm-camera terms). The WB1100F was released in early 2014.
Questions au sujet de 22 Voir tout
Camera fell in ocean, won’t turn on.
I recently went to the Bahamas. My camera fell off my chair and into the ocean. It was in the water for no more than 5 or 10 seconds. It turned back on and l saw the screen changing color, nothing since then. It didn’t have much sand in it but it still didn’t turn on. What’s the chances it can be repaired?
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
While not directly answering your question, you might be interested in reading the following in order to prevent further damage to yourself and your unit.
Electronics Water Damage
par
Ajouter un commentaire
1 Réponse
Unfortunately, 5 to 10 seconds of time spent in water is more than enough time to fry the motherboard. Although this may not be true to your device specifically, water damaged devices (even after attempted repairs) are very unreliable. They can work for 5 minutes, 5 days, or 5 weeks, but if it breaks again you’re out of luck. If there is personal data that you would like to retrieve, try sending it to a data recovery company such as “Drive Savers”. If you would still like to try and get it fixed, I personally don’t know of any companies that I could recommend.
I hoped this helped!
Indice 0
Ajouter une réponse
Linda Merriss sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 40
