Aller au contenu principal
iPhone 4 pouces commercialisé depuis mars 2016 avec une configuration de matériel similaire à l'iPhone 6s. Disponible en Argent, Gris sidéral, Or ou Or Rose, avec 16 ou 64 Gb de stockage. Modèles A1662 et A1723.
1049 questions Voir tout
iPhone SE won’t charge past 5% after port replacement!
Hey, had a guy on campus come to me who was having problems with his charging port, being really dirty or something, so I tried cleaning the port and came to the conclusion to just replace it. After replacing, the phone has problems charging, and won’t charge past 5%. It still had similar problems being weird with the charging when I plugged the old port back in. I bought the replacement port on amazon and did and didn’t do anything wrong in the replacement besides for there was this tiny metal bracket that I didn’t even see on the ifixit guide and didn’t remember where it went but assumed it wasn’t really important. I am pretty nervous as I don’t know what to tell this guy who thinks I broke his phone. Everything else regarding that same part work fine, like the speaker and headphone jack. I’m hoping it’s a battery issue but I’m not sure that’s what it is and I don’t want to have to buy a new battery for it to not fix the issue. What should I do/do you think it is?
Update (09/06/2019)
So, I looked for what you pointed out and it seems all of those pieces are attached. I don’t believe I messed up anything. But, now the phone is going to 100% when plugged in and 1% when it’s not, then turning off about 5 minutes after that. I tried to take pictures of the battery connector so you could see what I mean.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Do a thorough visual inspection, preferably with magnification, of the area surrounding the battery connector. There are several tiny SMD components just above the connector. Of particular importance is FL2400, at the top-left of the connector. If it is missing (which can happen when you pry the connector off), then the battery state does not get communicated to the CPU and this can also cause charging issues and fluctuating readings.
Indice 3
2 commentaires:
Just updated the question in response to your help
par
The picture isn't zoomed enough but it appears the component is in place. One thing to check for is if it is partially dislodged (one side of the component is no longer electrically connected to the board).
Beyond that, you either have a bad battery, charge port or damage to the charge circuit. Troubleshooting this will require some investment in parts and time.
par
Ajouter une réponse
Logan Davis sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 6
Total : 283
