Why when I pour water in my radiator it comes out of the oil drain plu
Just bought a 03 Murano took off the plastic that covers the radiator and found the radiator cap it was low on antifreeze I started filling it up and it was leaking on the right side of the engine I continued to fill with water to find the leak is think it's the oil cooler line easy to fix…. But now my oil has 2 gallons of water in the oil pan …pulled the plug and drained it out …now as fast as I put the water in it comes out of the oil drain plug…. please help thanks
2 commentaires
Yes I have the same problem on my car.
par FREDDY KUAM
Did anyone find a fix to this problem, I have an 07 Chrysler 300 3.5L Touring edition with the same issue. I changed head Gaskets 2 time and both times the coolant and oil mixed. I drained the third time and refilled the coolant reservoir to find out that the coolant was passing right through to the drain plug wtf...hoping someone has a solution km all out of ideas.
par Ruben Perales
