Aller au contenu principal
White Screen of Death + Corrupted in iTunes
My iPod Nano 3rd Gen recently stopped working. It shows a white screen and iTunes says it’s corrupted. I have tried normal restore and DFU restore. I have also opened it to check the display connector. Is the NAND dead? Is the display dead? The display has a line in it, and the iPod clicks. It makes me feel bad because this was my first handheld Apple device. Please help me!
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Hello. I’ve seen this a lot from when I repair broken iPods. The white screen of death is fairly common. Usually I don’t bother repairing this issue because it is usually caused by loose or damaged components on the motherboard from dropping it or age. You could open it up to see if there’s anything obvious but you are better off replacing it (Or at least replacing the motherboard) It is fairly cheap to replace the motherboard yourself but buying a new one isn’t going to cost much either.
Indice 0
1 commentaire:
I don't see any damage internally. Could this still be board-related?
par
Thanks for sharing this discussion as I also wanted have the similar answer. But if your device gets interrupted so you can get Geek Squad Protection Plan to experience better work flow.
Indice 0
Ajouter une réponse
TheYootz Media Group sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 88
