Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Écran de 7,9 pouces / Modèle A1454 / Disponible en noir ou blanc / Annoncé le 23 octobre 2012 / avec 16, 32 ou 64 Go de capacité
New LCD will not work after replacement
I sent this to a friend (cuz I was showing here how her iPad isn’t working even after I’ve replaced the LCD
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Have you made sure that the replacement LCD is not for an iPad Mini 2 being used on a iPad Mini 1 or vice versa? As the displays look very similar but are not compatible with each other.
The mini 2 LCD has smaller metal covers at the bottom of the LCD compared to the Mini 1 so make sure to compare old screen with new one. If they look the same in size it’s compatible.
Indice 0
1 commentaire:
I mean I did try 4 different lcds all from minis (wasn’t to sure if they were the EXACT MODEL since they all snapped in perfectly) and got nothing... Would it still make a difference even if every mini model fit on the iPad?
par
Have you checked for backlight failure? This generation of iPad is very sensitive to backlight fuse failure. You can test to see if any of the LCD’s are on when you put a flashlight to the surface.
If you see a picture, this means you will need to perform a micro soldering repair. Check out with article for more info:
Th screen stays black after a digitizer replacement..
Best of luck!
Indice 0
Ajouter une réponse
wm_alvarez sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 14
Total : 274
