LCD won't work, but everything else is great. Replaced LCD already.
Sorry, new to forum, so just posted same thing in similar thread, but shows up as answer, not a question, so posting again.
LCD screen not working - Replaced the LCD screen and still nothing.
Everything else is good with camera. Takes great photos, the EVF works OK. But too hard to use with ONLY the EVF.
Can think of 2 things;
1. Board on LCD fried - when replaced LCD used board from original
2.The button that switches between 3 options - LCD screen only, LCD screen & EVF or EVF only is STUCK?
The camera did get wet and I turned it on before realizing it was wet. When did this, the power button lit up, but then shut down. Once I dried everything out, all worked well (except the LCD screen).
Should I try to replace the board on the LCD? Suggestions on how to find the right one? Ordered 2 LCDs before I got the right one.
Would greatly appreciate any thoughts on what to try. Can’t afford to replace.
1 commentaire
Just some thoughts if I were facing the same situation as yourself. The position right now is whether or not either LCD is malfunctioning. Considering the camera was subjected to liquid infiltration, the possibility of component damage to the circuit board is a given. Ordering a new circuit board should allow you to determine the viability of either LCD, while returning the new LCD for a replacement (using the reason it is non-functioning) will not allow the bit more flexibility (pertaining to my frame of reference) in determining the cause of the failure to the camera.
That said and done, you might also want to consider the information contain in the following article with respect to the possibility of future corrosion issues:
Electronics Water Damage
par prop man
