Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Les installations d'eau et leurs canalisations, ainsi que la multitude de composants qui permettent leur bon fonctionnement.
Why does toilet bowl keep losing water
Why would both of my toilet bowls keep losing water? They flush fine, empty out and fills back up fine but after a bit of time I'll go back in and the water in the bowls have gotten really low. I've checked for leaks nothing there & the wax rings are fine I'm just losing water out of the toilet bowls and I don't know how or where it's going. I always hear the bathtub drains clicking everytime I flush & my neighbors downstairs flush. I live in a condo on the second level, no condo above me but my neighbors below me are now saying that they have water leaking into their place that they think is coming from my condo above them. Could that be because of my toilets and is it possible for it to leak down to their apartment?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
2 commentaires
I have the same problems too, but once I bought a new one problems solved, I wish I could help
par
I believe the answer lies in either a possible crack or the venting. I wanted to install a taller toilet anyway so I may see if that fixes the problem. Then go and clear the vent somehow. Thank you for your help!
par
Ajouter un commentaire
5 Réponses
Solution retenue
@stac69 of course, this may be a difficult question to answer since we do not know the make and model of your toilet ;-) Remember that the water stays at a given level because of the u-bend, which is called a trap, within the porcelain of your toilet. The shape of the bend will determine the height of the water level. So, it is possible that that there is a crack in the trap of the toilet its self and the water is slowly running down the drain (lucky you ). The other, and actually more common issue can be a clogged or improperly installed vent. One way you can check for a plugged vent by flushing the toilet, When the toilet then fills and the tank shuts off the water to the toilet, turn on the hot and cold water on the closest fixture to the toilet, most likely your sink or the tub. If the water level moves in the toilet you have a clogged vent. The change in the level will happen within minutes. Check the vent where it sticks up through the roof and look for obstructions. You can use a snake to snake out the vent stack or flush it with a garden hose (could be messy). The other problem can be a partially clogged downstream drain line. That could siphon the water out of the toilet. give your system a good cleaning with a snake and see what happens. Hope this helps, good luck.
Indice 3
4 commentaires:
I have a toilet in a bathroom that isn't being used that often. It has anther toilet on the other side of the wall that we use all of the time but the water doesn't go down in that toilet. They should be using the same vent pipe? When I turned on the water in the sink in the bathroom that we don't use the water does go down. There is also a tub in that bathroom. We live in a condo on the second floor. There are 4 floors in this building and 32 units. How can we fix this problem?? It does what you said it would when you turn on the sink water so it probably isn't the toilet that is bad right?
par
@jmbtoby6866 since it is a condo and has those adjoining toilets, my money is on a venting issue. There really isn't a lot that you can do. Maybe consider using the other toilet more often and see if that helps.
par
I'm going with @oldturkey03 on this one; my son just bought his first house and had drainage and suction issues. Traced it down to the vent line that allows air into the sewage system so when you flush or drain a sink or tub it has a supply of air instead of trying to draw from the water-filled traps in the rest of the system. The previous owner had a metal roof installed and for some reason cut off the vent and installed some sort of interior one-way valve that didn't work worth a crap. Simply loosening the clamp around the valve abated most of the problem and doesn't seem to be letting sewer fumes into the room.
par
I found a possible answer from another iFixit question
toilet bowl doesnt hold water
Indice 0
Your entire plumbing system will need to be replaced, all pipes , fixtures spicgots , washing machine , water heater ,meter and line from road to house , also replace your garden hoses as the have been damaged also
Indice 0
4 commentaires:
Sounds rather drastic to me; are you like bidding on this job or something?
par
🤣 hahaha..don't forget to replace the kids swimming pool too
par
No wonder plumbers make so much money, they rip you off
par
Seriously remember that when your sewage backs up and basement has foot of sewage in it!
par
The water loss could be from a hidden leak or a venting issue that’s slowly draining the bowls. That clicking in the drains might be the vents struggling, which can pull water out. Since your downstairs neighbors have leaks, there’s a chance water is escaping through shared plumbing. I’d start by checking the toilet base for hairline cracks, making sure the flapper in the tank seals tight, and looking (or listening) for any blockages in accessible vent pipes. If nothing turns up, the issue might be further along in the system and need a closer look.
Indice 0
3 commentaires:
Rizwan Khan, you seem to have missed the entire point of this site; to enable people to repair their own devices. As such, it's not helpful for them to tell them to call a plumber when they specifically came here to find out how to fix it themselves.
We do appreciate your contribution of ideas and possible solutions, but please refrain from sending people to professionals; that's exactly what they're trying to avoid.
par
@Jerry, I understand, and I’m sorry for missing the main point of the site. I’ll make sure my future responses focus on DIY repair steps so they’re truly helpful for those looking to fix things themselves. That's why I modify my previous reply. Thanks for pointing this out.
par
My toilet screams when flushing til it cuts off. What is it and how do I fix it?
par
For flapper determination for leaks drop some food colouring in the tank if it leaks into the bowl replace flapper
Indice 0
Ajouter une réponse
Stacey Pierce sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 108
7 derniers jours : 623
30 derniers jours : 3,267
Total : 166,235
