Aller au contenu principal
Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
20 questions Voir tout
Fan Known Broken but no Power LED
Hi All, I have a Mac Mini (mid 2011) that I have been given the Fan is known bad and will order a replacement, could that cause the system to not power on at all as trying to trouble shoot the machine, any help would be amazing?
james
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Before you order a fan, lets better understand why a dead system would even need a fan.
A dead system is often a bad power supply. It’s best to get the system working before you worry about the fan.
Remplacement de l'alimentation du Mac Mini mi-2011
This series also had issues with its logic board. There are two versions ones with just the Intel intergraded graphics engine and a second version with a dedicated GPU chip.
The dedicated GPU models tend to burnout the GPU chip from heavy CPU and GPU processing loads as the cooling was just not up to the task of cooling the system.
So lets first ID your system to see which one you have as you maybe end up needing a new logic board as well!
Plug in the systems S/N here EveryMac - Lookup
Indice 1
2 commentaires:
Hiya, here is the Mac that i have.
Mac mini "Core i5" 2.3 (Mid-2011)
2.3 GHz Core i5 (I5-2415M)
Model: A1347 (EMC 2442)
James
par
@cosmicoofman - OK, you have the IG model Mac mini 2.3 GHz Core i5 (Mid-2011) Good!
Lets replace the power supply and see where we stand.
par
Ajouter une réponse
James Jordan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 71
