Aller au contenu principal
Lancé le 20 septembre, le plus grand et plus cher smartphone Apple de l'année 2019 impressionne avec son écran OLED de 6,5 pouces, sa caméra à triple objectif et l'amélioration de l'autonomie de sa batterie. Il succède à l'iPhone XS Max.
Where is the microphone on iPhone 11 Pro Max?
Where is the microphone on iPhone 11 Pro Max? Is it on the side of the lightning charger hole (bottom) or at the top. (If at top, where someone thinks it is, how does that make sense when you’re on a call, using only the iPhone to speak into, with ear to phone? You mouth is close to the bottom (lightning port charge hole). Thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
Ajouter un commentaire
1 Réponse
Solution retenue
The microphone for calls would be located on the bottom left loudspeaker grill. The 2nd microphone for siri is on the proximity sensor flex cable, located right under your ear speaker on top. Finally the 3rd microphone is behind the device near your camera, it's a small tiny hole, used for picking up sounds when you're recording a video. I hope this helped.
Indice 5
4 commentaires:
When you have your phone against your ear the proximity detector will engage the camera & speaker mics to cancel the background noise both for your active mic as you are talking as well as the speaker if you are using hands free.
par
GREAT ANSWER!!!!!!!!!!! (had to have 20 characters to post)
par
I just ran a check that seems to contradict this answer: I put the iphone 11pro in video recording mode, and tapped first the lower left mic, second the top front mic and third the back mic located with the camera lense cluster. Then listening with earphones I played back the video. The only mic where I could hear the tapping was the first one, bottom left. According to this answer I should have heard the back mic, with the lenses...but no.
par
RE: Bill's comment -- at least as far as shooting video is concerned, if you use an app like Filmic Pro, you can select which mic you want working (under settings, audio.) You can also select your lens.
par
Ajouter une réponse
rachel.spencer999 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 26
30 derniers jours : 140
Total : 71,330
