Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le HP 15-da0012dx, numéro de modèle 4BS32UA, est un ordinateur portable sorti par HP en 2018. Il est équipé d'une vitre tactile de 15,6 pouces.
Adhesive choice for edges of screen after replacement?
I just replaced the screen on this laptop and now I am having trouble choosing an adhesive to use on the bottom edge of the laptop where the plastic frame attaches? Any suggestions would be greatly appreciated.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Low tack double sided tape if you insist on replacing it. You will be fine without it, but the part of the bezel with the HP logo may appear loose without any new tape. That said it's cosmetic and only matters if you care about looking passably stock. Even HP still uses screws on their bezels despite the move to tape being the norm, or makes the bezel clips strong enough to support themselves without tape being reinstalled.
Personally I wouldn’t replace it, but something like this will work if you insist on adding tape. Just make sure the permanent side (the part that comes off the roll without protection) goes on the bezel and not the LCD in case you need to service it - these new LCDs are so thin it doesn’t take much to break it again. Tape just complicates future service work because it creates removal problems especially on hybrid bezels it is completely unnecessary to use.
Indice 3
3 commentaires:
So I replaced my screen but when I went to put the bezel on I noticed I did something to the lcd because it looked like it bled on the inside ...i just ordered another to try again...how do you put the bezel back in without damaging the screen 😭😫???
par
Ps. I also didn't use tape to put it back could that be why?
par
@sparkcruz The trick on these is to snap from the outer edge and run your finger across. Make sure the bottom part gets done first and with more caution.
Not using tape saves time for future repairs, it doesn’t protect the bare panel.
par
Ajouter une réponse
Jorge Fuentes sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 34
Total : 2,003
