Aller au contenu principal
Un smartphone Android produit par Samsung et lancé en janvier 2017.
Why is my phone not charging and giving off a burning smell?
I have a Samsing Galaxy A5 (2017). One day it stopped charging and when plugged in, a burning smell is released from the charging port. The other end of the cable also gives off a burning smell. Any solutions, or advice on what I should replace? Also, what is the best adhesive/tape I can use to install the acrylic back after removing it? I’m looking for some adhesive that I can find somewere like bestbuy or walmart.
Thanks.
Répondre à cette question J'ai le même problème
Indice 1
3 commentaires
If my charging port smells like burning how do you stop it from burning
par
My galaxy a01 charger port smells like it's burning and this greasy stuff is on the back of my phone what is it? and what should I do?
par
How do I get it to charge again?
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
@thestrangeslav something on your charging circuitry went array. You want to go ahead and stop trying to charge it etc. Then you want to go ahead and disassemble your device. Start this by using these guides Samsung Galaxy A5 (2017) and/or this video Then check your circuit boards for obviously damaged components etc. Post some good pictures of your boards with your QUESTION. That way we can see what you see. Ajout d'images à une question existante
After that follow the troubleshooting steps as suggested on here
The connector IFC6001 is available at places like this
Indice 1
if you smell a burning smell at both ends of the cable try a different USB Adapter and see what it does. on the samsung galaxy a5 it does not use adhesive, the screen just clips in.
Indice 0
2 commentaires:
Actually this model the screen is held by very strong adhesive. There is also adhesive for the back glass.
It sounds like the USB-C charging socket on the phone needs to be replaced. This is quite difficult to do as it is soldered onto the logic board. This I would leave it to a local reputable phone repair shop to get it fixed.
First thing to do is try another wall charger and cable if you still smell the same electrical burning smell it means the problem is with the charger port instead.
par
go look up a disassembly on a samsung galaxy a5
par
if you smell burning it was caused by electricity and is melting/ burning something change USB adaptor see if that works if not change the charging board in the phone.
Indice 0
1 commentaire:
Ayden Aldrich so what's the fix? How can you help the OP repairing his device? How does your answer help the OP?
par
Ajouter une réponse
David sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 32
30 derniers jours : 146
Total : 34,516
