How to replace a Home Buttom
How Can i replace a bad home buttom on aiphone 3gs.
Albert,
Follow the front panel replacement guide here:
Remplacement du panneau frontal de l'iPhone 3GS
When you get to steps 12 thru 18 you will see the home button and all you do is remove the home button itself and the ribbon cable / switch under the home button is adhered to the frame so use a spudger to unstick it, slide it out through the case and the new one slides in and is attached with adhesive.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,357
