Vauxhall Corsa 08 blower is working one day but not the next
Hi. I know this is an old post but wondering if anybody can help me.. I have a Vauxhall Corsa 08 plate and the blower is working one day but not the next and it is causing me problems with seeing to drive in the damp/cold weather.
Any ideas what it could be as I don't have much money at the moment so dreading it but it needs doing asap.
Indice
you will start at the blower motor itself, hotwire it with power and ground, if that works then work your way backwards in the system, the blower resister is usually next in line and a big problem on many cars. Looking for burned connectors, broken resisters and then tapping on the main control unit and wiggle the wires connected to it may find the problem, if your blower is intermittant, it probably is not a bad fuse but could be a weak connection, a volt meter will do a lot of the troubleshooting for you once you get access to the connectors, lots of information on youtube.
Answer provided by Duane Donaldson
par jayeff
Hi @ Duane Donaldson,
I've moved your good comment to a "Answer" (which was actually a question) in another thread to a new question and "comment" to move it away from a Honda question to a Vauxhall question in case others are looking for Vauxhall problems and never find it.
Could you please copy your comment above and post it here as an answer so that you will get recognized as the author of the answer.
I will then delete "my comment" so that your answer remains and you get the credit
Cheers
par jayeff
