Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Commercialisé en janvier 2015, le portable XPS 13 se veut un concurrent du MacBook Air, avec un "écran sans bordures " et une option de mise à niveau à écran tactile.
Four flashes. Battery isn’t recognized by laptop.
Just replaced my dying battery with one from ifixit.
The white charging light appears when I attach the ac adapter, then I get four orange flashes.
The internet says this means a bad battery. Did I receive a bad battery or is there something else that could be at play here?
EPILOGUE: I followed the recommendation, started the process. For giggles, I unplugged and repeated the connection and realized it had been user error. Fixit troubleshooting 101.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
Hi,
What happens if you leave it on charge for a while, does it stop flashing?
Have you tried re-installing the old battery to check if the problem is still there, assuming that it didn't do this before?
par
Ajouter un commentaire
2 Réponses
Solution retenue
EPILOGUE: I followed the recommendation of jayeff and started the process of confirming connectivity with the old battery. For giggles, I unplugged and repeated the connection and realized it had been user error. I just hadn’t pushed the connector in far enough. Shame on me. Fixit troubleshooting 101.
Indice 0
1 commentaire:
I am having the same problem you've described, but with no luck on playing with the connection. The old battery re-connected just fine, but the ifixit battery didn't. After hours of sitting plugged in, the flashing orange light continues, and when I unplug the computer it immediately dies. So the battery isn't connecting. Makes me wonder if i got a bad battery.
par
Réponse la plus utile
discosammy enter the "Epilogue" as an answer so we can mark this question as resolved.
Indice 1
Ajouter une réponse
discosammy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 1,331
