Aller au contenu principal
Sortie en juin 2016, s'identifie au numéro de modèle A3003 en Europe et A3000 en Chine et en Amérique du Nord. (Source : https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
20 questions Voir tout
Digitizer does not work after screen replacement
I replaced screen and digitizer and it seems everything went fine. The phone turns on but the touch doesn't work, the back and all app button do work. I tried doing a factory reset but it stills doesn't work. What could be the problem?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi Neil,
I would suggest disconnecting and re-seating the display cable. Carefully check the connector for any debris—the pins on the connectors are tiny.
Remplacement de l'écran avec vitre tactile du OnePlus 3
Indice 1
2 commentaires:
Hello Arthur,
I tried disconnecting and re-seating the display cable as you suggested but still nothing. Could it be a motherboard problem or should I send back the display+digitalizer and try with another one?
par
Hey Neil,
It could be a motherboard, though I'd think that the display may have a slightly higher chance of being the problem. Does the original screen work enough to be used as a test? Unfortunately with how the replacement is set up, it's not easy to swap displays.
par
Ajouter une réponse
Neil Considine sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 265
