Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Why is my phone restarting itself
My phone keeps restarting itself, when I switch it on, the screen reads android is starting , optimizing APP 1 OF 1, then reads starting app, vibrates once switches on for less than 5 seconds then restarts again. It continues to restarts itself until battery runs flat.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi @annah44 ,
Things to try without resorting to a factory reset.
Try clearing the phone’s cache partition and check if this resolves the problem.
DO NOT select wipe data/factory reset as this will erase all your data and downloaded apps and reinstall the operating system.
Try starting the phone in safe mode and see if the stops boot looping.
If it does then a downloaded app is the cause of the problem. The trick is to find out which one is the culprit.
You will need to uninstall each downloaded app, one by one and test the phone in normal mode between each uninstall to check if the problem is still there or not. When it is OK then the last downloaded app that was uninstalled was the cause of the problem.
Indice 2
2 commentaires:
please show me how to uninstall app
par
@surekhakane
Here's the Galaxy J5 Prime user manual. Go to p.47 to see how to uninstall apps.
par
Ajouter une réponse
Annah Chiweshe sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 23
Total : 1,166
