Am I able to take out the throttle control motor relay out of ipdm
I just need to know if I'm able to take out the relay for throttle control motor in the ipdm. . My car goes into limp mode but if I tap on that relay it goes back to normal driving conditions.. i just dont wanna force it out and not be able to put a new one in.. but a new ipdm is out of my budget for the second..any suggestions or ideas would be greatly appreciated
Hi @danielv661 ,
Do you know why the car is going into limp mode?
What are the OBDII scan codes showing?
You may cause serious damage to the engine if you bypass a feature that is designed to protect the engine and get you home (or at least to a mechanic) in the event of abnormal operation.
par jayeff
I'm not wanting to bypass it.. I want to replace it with another one..I just wasnt sure if I could take it out without damaging the ipdm. . If I take it out my rpms wont go past 1000 or so.. but I'm pretty sure the relay is my problem. Or the oem. The code was p1128 I beleive.. open circuit in throttle control. Then while I was checking out the relays the throttle control motor relay clicked then the car was fine...but if I'm driving over bumps or something like that the relays shorts again.. I then have to pull over and tap on the ipdm then it starts back up
par Daniel velasquez
Also wanna say thank u for the quick response..really appreciate it
