Aller au contenu principal
Screen doesnt work after battery replacement
After I replaced the battery of my ipod nano 3 the only display like a white color.
Everytime I reset it, it makes two beeps after starting. I tried resetting via iTunes, the iPod itself and getting into the diagnostics mode. I can hear the iPod making click sounds when I use the buttons. I checked the display ribbon cable multiple times and made sure it is properly stuck in there.
I afraid I fried my screen because I can´t disconnect the battery before connecting the screen since it is soldered on. Do I need a new screen or is a connectiong loose?
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
I rechecked the the display connection and made sure it properly sits in there but what do these two beeps mean? Also could I have fried the display because I connected it while the battery was connected? It was working fine before.
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Philipp Udwari  the white screen means that our backlight is on but no video signal. You do need to check the connector and make sure that the cable is straight and properly seated. If all of that works out, the next step would be a replacement display.
Indice 1
1 commentaire:
par
Ajouter une réponse
Philipp Udwari sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 64
