Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Strange audio distortion on stylo 5
on the Stylo 5 has built-in digital analog converter and Dolby DTX:X surround sound and I usually plug it in with my pair of Sennheiser 6xx headphones I have used them on my other devices basically a Samsung Galaxy s6 in this issue has not shown up on the s6 the stylo is messing up the audio signal and making that weird static sound and it transmits over to Bluetooth it's mostly happens in heavy Bass songs that go down to at least 32hz sometimes 10hz I started using my other pair of headphones to see if they issue went over through Bluetooth I am using a pair of bludio v 6 driver per side headphones the issues happens on that too I've been using an application that steps in and boosts up the bass it is called bassbooster by mvm it increases the frequency to make more better punching bass and on the Stylo it makes it distort there is no way to disable the built-in EQ on the phone and I've been trying to figure out how to disable it but I really don't know whats happening.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi Hayden,
I know how much sad it is. In your case, the problem can most probably be faulty equipment.
To fix the issue, you can try following methods:
1. Change other contacts to call the test.
2. As it is a Bluetooth headset, please reconnect the phone to the Bluetooth headset and try again.
3. Try replacing other Bluetooth earphones/wired earphones.
4. If there is still noise after replacing the headset, please backup the data (contact person, SMS, photo, etc.) to eliminate third-party software problems and restore the factory Settings.
5. If the problem still exists, it is recommended that you bring the machine, purchase invoice and package repair card to the local LG after-sales service center for testing.
Hope my answer helps you, and please also keep me updated, thanks a lot!
Indice 0
2 commentaires:
Yeah its the lg phone im going to factory rest it
par
@hayden4586 Make sure back up anything importand beforehand.
par
Ajouter une réponse
Hayden Rogers sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 27
Total : 3,117
