Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le OnePlus 6T est un smartphone Android fabriqué par OnePlus. Il a été annoncé le 29 octobre 2018 et commercialisé le 6 novembre 2018.
I Accidentally scraped my battery
I accidentally scraped my phone battery a couple of times while removing the back panel of my OnePlus 6T. Should I replace the battery or will this battery still work like this? It is not punctured at all, just has some grooves on top
Répondre à cette question J'ai le même problème
Indice 0
2 commentaires
You should never use damaged batteries but you can add a picture of it so we can see how damaged it is.
Ajout d'images à une question existante
par
Picture added to the question. If I may add, I have already charged and gone through 3 cycle charges and the battery does not overheat or anything. Would this still be considered heavily/dangerously damaged?
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Even if it works fine, replace it. Normally I wouldn’t be concerned about a very, very light surface scratch but these are deep enough to warrant replacing it. Softcells have zero protection like old modular ones in a metal case.
It may be fine, but it’s not worth the risk since softcells are so easy to damage. The battery can be found here.
Image Replace a BLP685 model battery compatible with OnePlus 6T and 7 model smartphones. 3610 mAh. 3.85 Volts (V). 13.89 Watt Hours (Wh).
Produit
OnePlus 6T and 7 Battery
$14.99
Indice 1
Never used damaged batteries in devices, especially if you get the smell of rubbing alcohol or burnt skittles as other people have described it.
Indice 0
2 commentaires:
I just added a picture To my question. No smell is coming out of it. I'm just worried if those grooves may be considered dangerously damaged or not. Can I please get your feedback on it?
par
Yeah I'm concerned about those grooves. I would get a replacement, it's not worth the potential third degree burns.
par
Ajouter une réponse
Alberto sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 790
